In my config, I already have “virtual” sensor that calculates outdoor sunlight “percentage” (Got it from the forum). It works fine.
Now I want to use this sensor to set the kitchen light brightness to the same level of outdoor sunlight. I search forum, internet and didn’t find the answer to my problem.
My code looks like this in my automations.yaml file :
- id: '1600635450840'
alias: 'Lumières cuisine :: Auto luminosité'
description: ''
- platform: device
type: turned_on
device_id: 82e8a2e8ce894c6ba6c70d8e2a7fe47e
entity_id: light.lumieres_cuisine
domain: light
condition: []
- type: turn_on
domain: light
data_template:
brightness_pct: >
{{ sensor.sunlight_pct.state|float }}
mode: single
When I try to reload the Automations, I get this error in the log file. Looks like I’m not giving a float value or something. As you can see, I tried the “|float” but no luck.
Logger: homeassistant.config
Source: config.py:413
First occurred: 17:01:31 (3 occurrences)
Last logged: 17:07:01
Invalid config for [automation]: expected float for dictionary value @ data['brightness_pct']. Got None. (See /config/configuration.yaml, line 94).
Invalid config for [automation]: [data_template] is an invalid option for [automation]. Check: automation->data_template. (See /config/configuration.yaml, line 94).
Thanks in advance from this n00b !
