Todan
(Tomas Bach-Danielsson)
1
On the page https://www.home-assistant.io/docs/automation/action/ there are no example on publish state over MQTT broker .
I would like to set up an automation that ower MQTT turn on a lamp at time 21:15:00
The code bellow works fine when troggel the light from the dashboard.
light:
- platform: mqtt
command_topic: "inLight"
state_topic: "inLight"
payload_on: "0"
payload_off: "1"
retain: true
my code on controler
if (client.connect("Light"))
Serial.println("Light - MQTT - OK");
client.subscribe("inLight");
in /config/automations.yaml i have this code, that i think has to be modified , So do anyone has a sugestion ?
- id: 'xxxxxxxxx'
alias: mqtt turn on light
description: ''
- platform: time
at: '21:15:00'
condition: []
- service: mqtt.publish
light.turn_on: true
mode: restart
nickrout
(Nick Rout)
2
The action is light.turn_on
, home assistant communicates to the MQTT broker when it turns the light on.
Todan
3
Thank you for your comment.
I have edit my post and added the code in /config/automations.yaml. This code dos not work for me.
nickrout
(Nick Rout)
4
light.turn_on
is a service. It should be:
- service: light.turn_on
entity_id light.whatever
Todan
5
Hi i got this error code:
“Message malformed: extra keys not allowed @ data[‘action’][0][‘action’]”
entity_id light.inLight
Todan
6
Hi. I found the correct syntax.
Thank you for your support, have a nice day / Tomas
service: light.turn_off
data: {}
entity_id: light.light
nickrout
(Nick Rout)
7
Sorry about that, looks like you figured it though
