I don’t know if I remember incorrectly, but I think you used to be able to add automations in a scene in the past, from the UI. However, now I what to be able to call a automations when a scene is activated, the stuf I find on the internet did not work, can someone help me?
Add the automation entity to the scene in the UI?
How?
I want to run a automation when a scene is activated, is that possible
When a scene is activated, its state
value contains the date and time when the activation occurred. An automation can use a State Trigger to listen for changes to the scene’s state
value.
alias: example
- platform: state
entity_id: scene.your_scene
condition: []
... your actions ...
I will try that! Thank you, i will retur with an answer
