I have an idea but I’m just unsure how to deploy it.
I have my solar inverters x2 into HA and I can do simple automation. ie when sun is up reduce battery max charge to 25. This is because we have an export limit of 4.7 kWh. So I try and make it so instead of more power at one time send power for longer.
This is working but I want to tweak it.
Say if my export is at 3000w for 5mins I then want to add 5 amp to each inverter max charge. I’m trying to get the most of the system without being throttled.
The problem I have is I just can not work out how to add 5 to the both entities up to a max of 85.
if not, put pseudocode into the code where you want it to do something different.
by the way, when you respond, if you want a faster response, hit reply on my post, don’t hit blue reply on the bottom of the thread. replying to someone’s post will notify them that they have a reply. replying on the thread won’t…
