hello,
i regularly do have this warning in my logs, not sure if this is a problem, but sometimes hassio is very slow, so i wonder if this is related to?
i understand that automation is still running, when a new trigger is fired und this message could be “suppresed” by max_exceeded silent
But i dont understand why this automation could sill running, why does it not end?
when does a mode: single
automation stoppes action?
and what i dont understand: 1 occourances, last logged at the same time as first? what does it mean´for automation? could it now still finisihed running? But only at this moment of a trigger it was still running and is logged?
is it possible to log, when a automation is triggered and when it has successfull stopped from running?
Logger: homeassistant.components.automation.heiz_bad_v4
Source: helpers/script.py:1783
Integration: Automation (documentation, issues)
First occurred: 07:00:00 (1 occurrences)
Last logged: 07:00:00
Heiz_Bad_v4: Already running
here my automation: what could prevent is from stopping?
alias: Heiz_Bad_v4
description: ""
- platform: state
entity_id:
- schedule.heiz_bad
to: "on"
- platform: state
entity_id:
- schedule.heiz_bad
to: "off"
- platform: state
entity_id:
- schedule.heiz_bad_boost
to: "on"
- platform: state
entity_id:
to: "off"
- platform: state
entity_id:
- input_boolean.heiz_mainswitch
to: "off"
- platform: state
entity_id:
to: "on"
condition: []
- service: climate.set_temperature
temperature: >-
{% if ( (is_state('input_boolean.heiz_mainswitch','on')) and
(is_state('schedule.heiz_bad_boost','on')) ) %}
{{ states('input_number.heiz_bad_tempboost') }}
{% elif ( (is_state('input_boolean.heiz_mainswitch','on')) and
(is_state('schedule.heiz_bad','on')) ) %}
{{ states('input_number.heiz_bad_temphigh') }}
(is_state('schedule.heiz_bad','off')) ) %}
{{ states('input_number.heiz_bad_templow') }}
(is_state('schedule.heiz_bad_boost','off')) ) %}
{% else %}
6 {# just for monitoring#}
{% endif %}
entity_id: climate.trv_56_heizung_bad
- service: climate.set_hvac_mode
hvac_mode: |-
{% if is_state('input_boolean.heiz_mainswitch','on') %}
heat
{% elif is_state('input_boolean.heiz_mainswitch','off') %}
off
{% else %}
{% endif %}
mode: single
thank you in advance
br
Frank
