Hello!
I use OpenWeatherMap (once_hourly) and the following in templates.yaml
(included in configuration.yaml
- name: Frost Alert
unique_id: frost_alert
state: >
{% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%}
{% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%}
{% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%}
{% set result_frost_alert = temp_frost_alert < 4 %}
{{result_frost_alert}}
- name: Frost Temperature
unique_id: frost_temperature
state: >
{{temp_frost_alert}}
- name: Frost Time
unique_id: frost_time
state: >
{% set time_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | selectattr("temperature", "eq", temp_frost_alert)| map(attribute="datetime") | list | join )%}
{{as_timestamp(time_frost_alert) | timestamp_custom("%H:%M")}}
(source: Home Assistant Frost Alert - daniel-strohbach.de)
In principle it works, i.e. I get automated notifications about potential frost, but I don’t know how to solve these related errors in the log:
Logger: homeassistant.helpers.event
Source: helpers/template.py:570
First occurred: 08:20:28 (1 occurrences)
Last logged: 08:20:28
Error while processing template: Template<template=({% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%} {% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%} {% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%} {% set result_frost_alert = temp_frost_alert < 4 %} {% set time_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | selectattr("temperature", "eq", temp_frost_alert)| map(attribute="datetime") | list | join )%} {{as_timestamp(time_frost_alert) | timestamp_custom("%H:%M")}}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1821, in forgiving_as_timestamp
return dt_util.as_timestamp(value)
File "/usr/src/homeassistant/homeassistant/util/dt.py", line 135, in as_timestamp
raise ValueError("not a valid date/time.")
ValueError: not a valid date/time.
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 568, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2196, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 3, in top-level template code
File "/usr/local/lib/python3.11/site-packages/jinja2/sandbox.py", line 393, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1824, in forgiving_as_timestamp
raise_no_default("as_timestamp", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1626, in raise_no_default
raise ValueError(
ValueError: Template error: as_timestamp got invalid input '2023-10-18T04:00:00+00:002023-10-18T05:00:00+00:00' when rendering template '{% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%} {% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%} {% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%} {% set result_frost_alert = temp_frost_alert < 4 %}
{{as_timestamp(time_frost_alert) | timestamp_custom("%H:%M")}}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 694, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 570, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: as_timestamp got invalid input '2023-10-18T04:00:00+00:002023-10-18T05:00:00+00:00' when rendering template '{% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%} {% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%} {% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%} {% set result_frost_alert = temp_frost_alert < 4 %}
And:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:194
Integration: Template (documentation, issues)
TemplateError('ValueError: Template error: as_timestamp got invalid input '2023-10-18T04:00:00+00:002023-10-18T05:00:00+00:00' when rendering template '{% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%} {% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%} {% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%} {% set result_frost_alert = temp_frost_alert < 4 %} {% set time_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | selectattr("temperature", "eq", temp_frost_alert)| map(attribute="datetime") | list | join )%} {{as_timestamp(time_frost_alert) | timestamp_custom("%H:%M")}}' but no default was specified') while processing template 'Template<template=({% set start = (now().date()+ timedelta(days=1)) | string + "T04:00:00+00:00"%} {% set end = (now().date()+ timedelta(days=1)) | string + "T08:00:00+00:00"%} {% set temp_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | map(attribute="temperature") | list | min)%} {% set result_frost_alert = temp_frost_alert < 4 %} {% set time_frost_alert = (state_attr('weather.openweathermap_hourly', 'forecast') | selectattr("datetime", ">=", start) | selectattr("datetime", "<=", end) | selectattr("temperature", "eq", temp_frost_alert)| map(attribute="datetime") | list | join )%} {{as_timestamp(time_frost_alert) | timestamp_custom("%H:%M")}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.frost_time'
Any help is very much appreciated - thank you!
