Hey all, I’m trying to understand how trigger names can be used in automations. I have a simple thing, I have a switch which turns on at 8am and off a 8pm. I wanted to just make an automation with two triggers, on at 8:00 off a 20:00. Can I use those both in one automation to do different things? It’s kind of dumb now, I have one automation to turn it on and one to turn it off.
Yes, you can.
alias: Scheduled Switch
- platform: time
at:
- '08:00:00'
- '20:00:00'
- service: "switch.turn_{{ 'on' if now().hour == 8 else 'off' }}"
entity_id: switch.whatever
Another alternative, though not as compact as Taras’ suggestion, this can survive Home Assistant crash/restart should it happen at 8AM/8PM-
- platform: time
at: '08:00'
- platform: time
at: '20:00'
- platform: homeassistant
event: start
condition: []
- choose:
- conditions:
- condition: time
after: '08:00'
before: '20:00'
sequence:
- service: switch.turn_on
entity_id: switch.your_switch
default:
- service: switch.turn_off
I can be equally compact by simply enhancing the template:
- platform: time
at:
- '08:00:00'
- '20:00:00'
event: start
- service: "switch.turn_{{ 'on' if 8 <= now().hour < 20 else 'off' }}"
Awesome! Thank you!
Hey, I’m missing something here, what is the default action? I’m just trying to set this up through the UI, do I have to do this in the yaml?
Why suffer? Just switch the Automation Editor from visual to YAML mode then copy-paste the example I posted above. Save it and done.
