I have the below automation set for HA to do something based on whether I enter or leave home. This works fine, but wondering if there’s a cleaner method of setting the Trigger, ie. instead of ‘or’ as I presently have it?
alias: Presence - Home (Scott)
description: ""
- platform: zone
entity_id: person.scott
zone: zone.home
event: enter
enabled: true
- platform: zone
zone: zone.home
event: leave
condition: []
I don’t now if it’s any “cleaner”, but you can use a State trigger based on the person
entity:
description: ""
- platform: state
to:
- home
- not_home
- home
- not_home
condition: []
or
description: ""
- platform: state
to: null
condition:
- "{{ trigger.to_state.state in ['home', 'not_home'] and trigger.from_state.state in ['home', 'not_home']}}"
I guess the first could be split into 2 triggers and not require any manual configuration… I haven’t seen any discussion of adding the ability for multiple selections to the State trigger, but I also don’t regularly keep an eye on the frontend arch. discussion boards.
For many use cases they’re interchangeable. One significant difference is that Zone trigger (entering/leaving) requires a device tracker platform that supports reporting GPS coordinates. State trigger will work with non-GPS device trackers as well but, IIRC, will not work with passive zones.
