Automation Based on Door Sensor and Sun State not working
I am trying the following automation
if my garage door is opened between the Sunset and Sunrise I wanted to turn on the Garage light Switch.
I also wanted to turn of the lights 5 minutes after the door is closed, ( I haven’t added this part yet, as I am not sure how do do that)
Here is my Automation YAML
alias: Tun on the Garage Lights if Garage Entrance Door is open
description: ''
  - platform: state
    entity_id: binary_sensor.garage_door
    to: 'on'
condition:
  - condition: sun
    after: sunset
    before: sunrise
  - service: switch.turn_on
      entity_id: switch.garage_light_mss550x_main_channel
mode: single
My automation is not triggering or running, can someone tell me what am I doing wrong here? Also can you please guide me on what configuration I have to add to turn of the lights 5 mins after I close the door
I got this automation to work by changing the script to the following
 alias: 'Garage Light when door is opened '
description: ''
  - platform: state
    to: 'on'
condition:
  - condition: or
    conditions:
      - condition: sun
        after: sunset
      - condition: sun
        before: sunrise
mode: single
However still not sure how do I configure it to turn off 5 mins after closing the door, should I create another automation for it or can I get achieve it from single automation ?
you could add to the actions after turning light on and add a wait for state, door closed, delay 5 mins, turn off light.
This would mean the automation is always running all the time the door has been opened subject to the conditions set of course and I know some people don’t like leaving automations running for any great length of time in case of HA restarts or editing automations etc
So you could also if required make a separate automation that simply turns off light if state of door has been closed for 5 mins.
Try this:
description: ''
  - platform: state
    to: 'on'
condition:
  - condition: state
    entity_id: sun.sun
    state: above_horizon
mode: single
Thanks for the clarification @rossk, I added an additional automation to turn off the lights after the dorr sensor changes the state from on to off
