I try to play some TTS as soon as my coffeemaker has the correct temperature.
But for some reason, the automation ‘Coffeemaker pre heating’ is never triggered.
Has anybody tried something similar with the Fibaro Wall Plug?
When I look at the values in the frontend I can see that the sensor reports a spike up to 980 W.
I found the error myself. I was using the wrong sensor. Instead of ‘fibaro_system_fgwpe_wall_plug_power_2_8’ I should have used ‘fibaro_system_fgwpe_wall_plug_power_2_4’.
Now it works.
OK, I get it now - I’m doing a similar thing with one of my automations.
Glad you figured it out - wrong sensor; isn’t it always the last thing you’d think of too? For me it’s always mispelling or transposed letters. I seem to type dyslexic even though I have no problem reading. It forces me to double and triple check my YAML.
I am trying to do some similar stuff with my efergy energy monitor. Just one query to your setup, does it trigger if the value is 510.5 or some floating value ? I know, logically 510.5 is still above 500 so condition is met but I am not sure the data type can play a role here or not ?
The reason for my asking is, yours config looks pretty simple and easy to understand but I saw others doing in a very different way (using the value template and creating some binary sensor ). when anything comes to templating , I am just plain lost.
Yeah I already figured it out. Thanx a lot for guiding me towards the right direction in a simplest way…
I have configured the automation to send me push notification when the reported output is above 3.5 kW , well it’s working flawlessly so far.
I am glad that I didn’t have to mess with the templating.
