I have created an automation that notifies me if the garage was left open for 4 min. Using Choices and triggers, the same automation also notifies me when it closes. However, today it notifies on close every time it closes. Instead I would like it to only notify me on close if the 4min trigger preceded it. Thoughts?
alias: Garage door open alert
description: Sends a notification if the Garage Door is open over 4min
- type: opened
platform: device
device_id: e7d69ba0dfdf89334ff9596912f6c97d
entity_id: e85f5889496d6c967a7a67cb0fa4da31
domain: binary_sensor
for:
hours: 0
minutes: 4
seconds: 0
id: Garage left open 4min
- type: not_opened
platform: device
condition: []
- choose:
- conditions:
- condition: trigger
id:
- Garage left open 4min
sequence:
- service: notify.mobile_app_phone
message: Garage open for 4 min
- conditions:
id:
- Garage Closed
sequence:
message: Garage closed
mode: single
If you put the close notification in a separate automation, then you could enable that automation with the 4 min warning and disable it when you issue the close notification.
There are a few ways to do this. You could do it using a Wait for trigger following the original opening message instead of using a Choose action:
- type: opened
platform: device
for:
hours: 0
minutes: 4
seconds: 0
condition: []
- wait_for_trigger:
timeout: "00:10:00"
continue_on_timeout: false
- type: not_opened
platform: device
mode: restart
Make sure to review the Wait for Trigger doc and assign an appropriate timeout for your wait so the automation isn’t left in a waiting state for an excessive amount of time.
Another option is to use a template to check the state object of the door sensor. While this could be done in the condition of the Choose option, in the automation that follows it is moved to the Condition block. This should help keep the automation’s debug traces from being filled with door closing events unrelated to prolonged opening.
- platform: state
to: 'on'
for: "00:04:00"
id: Garage open for 4 min
variables:
long_enough: true
- platform: state
to: 'off'
variables:
long_enough: "{{ now() - trigger.from_state.last_changed >= timedelta(minutes=4)}}"
condition:
- "{{ long_enough }}"
message: "{{ trigger.id }}"
mode: single
