Automation based on presence
Hi there,
I currently stuck, so please excuse this probably dumb question. I am trying to run an automation based on “presence”, which does not work yet and I don’t know why.
The “automation” task is quite simple (I think):
  • My TV is on a RF power outlet, so when I have turned the TV off, I want to switch it off completely after a while. (TV off --> turn power outet off.)
  • I can also turn on the power outlet with a remote which is not monitored, I’m trying to “correct” the state as well for this case. (TV on --> power outlet must be on --> set power outlet on in HA)
  • I can see the status of my TV based on network presence (and it’s correctly shown as ‘home’ or not in HA).
Therefore I tried this, but it does not seem to work. From my understanding, the automation is not triggered. Any help is appreciated.
- id: 'turn_off_tv_plug'
  alias: Turn off TV-Plug
  - entity_id: device_tracker.tv
    platform: state
    for:
      minutes: 5
    to: 'not_home'
    service: switch.turn_off
    entity_id: switch.tv_plug
- id: 'correct_tv_state'
  alias: Correct TV State
    platform: state
    to: 'home'
  - entity_id: switch.tv_plug
    service: switch.turn_on
Thanks very much!
Fo
EDIT: As this came up twice, I think I did not describe the second automation clear enough. I can turn on the rf power outlet manually, so HA does not know it is on (but it is physically on). So the TV can be on even though HA still thinks that the outlet is off. Therefore the second automation should not actually turn it on but only set the correct state (as it is already on) in HA.
first automation looks correct. does the switch work from HA? can you toggle it manually in HA?
The second automation cant ever work. The tv cant report on if the power source is off.
Hi!
Thanks for your quick reply.
I can turn the switch on and off from the HA interface, but it will not turn off based on the autmation.
The second autmation should also work as the power source is not actually off. I can turn it on directly, without HA. In this case the power source (433 Mhz outlet) would be on but HA still shows it switched off. As the TV will be online, I 'm trying to use this as an indicator to correct the state.
of for 1st try this: (missing the slash)
  - service: switch.turn_off
the second still wont work. you need the tv on to trigger the automation to turn on the rf plug. how do you power the tv before powering the plug?
Thank you for your reply. I will try your suggestion when I’m back home.
I also edited my initial post with some explanation for the second automation, I agree that it seems ridiculous, but it actually makes sense in the current implementation.
ohhhh, I see :slight_smile:
so the automation is just to update the state of the plug.
ok try my suggestion for number 1
If think it should be like this:
    platform: state
    for:
      minutes: 5
    to: 'not_home'
    - data:
The hyphen did the trick, thank you!
I really have to learn where hyphens are necessary.
good to know. yaml has it’s rules. but you’ll get them in no time.
