Setup; I have an input.boolean, that is on when the washing machine goes on (the logic for that is in another automation). I want to turn that input boolean off if the following conditions are met:
The power is below 20 watts for more then 2 minutes
OR
The power is below 40 watts for more then 2 minutes AND the machine (that is the input boolean) has been on for at least and hour.
I tried the automation underneath, but it seems like “for:” is not allowed for “numeric state” only “state”. Any suggestions on how to solve this?
- alias: Vaskemaskin av
#triggers when the machhine goes on
- platform: state
entity_id: input_boolean.kjellerbad_vaskemaskin
to: 'on'
condition:
condition: or
#conditon 1
conditions:
- condition: numeric_state
entity_id: sensor.kjellerbad_vaskemaskin_power
below: 20
for:
seconds: 120
#condition 2
- condition: and
conditions:
below: 40
for:
seconds: 120
- condition: state
state: 'on'
for:
minutes: 60
service: input_boolean.turn_off
Thanks, but what will happen for that suggestion if after 1 hours and 5 minutes, it goes below 40 for 3 seconds. Won’t it trigger then? In my first automation (besides the fact that it doesn’t work :)) it will only trigger if more than an hour has passed and it is below 40 for 2 minutes.
Triggers cause an automation to be considered when they become true. Not after. When input_boolean.kjellerbad_vaskemaskin has been on for one hour, that trigger will become true, and the automation will start processing. One second later when it is still true it won’t cause the automation to start processing.
So, the automation will only process at the exact points that:
sensor.kjellerbad_vaskemaskin_power has gone from above 20 to below 20 for 2 minutes
sensor.kjellerbad_vaskemaskin_power has gone from above 40 to below 40 for 2 minutes
So, at one hour and 5 minutes, there’s nothing to cause it to trigger if the sensor goes below 40 for 3 seconds…
Ok, so then one could just remove the last trigger then, right? And how about the “below” condition? That might not be necessary as it if checked for in the trigger itself?
The automation covers the logic you described in the opening post. If you remove any of the triggers, or conditions, you won’t get the behaviour you described.
Thanks, but it still seem to me like it is not quite doing the same:
I still don’t get usefulness of trigger 3? (the time 1), why should it trigger exactly at 1 hour?
Lets say after 45 minutes it will be at 30 (below 40 and above 20) for 2 minutes, and the goes over to 10 for 5 seconds. Trigger 2 will activate, it will check if it is below 20 in condition 2 (which it is), and thus run the action. But it shouldn’t because because it hasn’t been below 20, 2 minutes in a row within the first hour?
Ideally the “below 20”-condition should be active after 1 hour as well, it just should add the “below 40 for 2 minutes” as an added situation.
It checks all the time if it has been below 40 for 2 minutes? That is your trigger 2? That will check that all of the time, no matter if it has been an hour or not, right? So what does trigger 3 do?
No, the point is for it to activate if it has been below 20 for 2 minutes. OR if it has been been below 40 for 2 minutes after an hour has elapsed. But the first one fails in the example I have provided right? It will activate even if it hasn’t been below 20 for 2 minutes the first hour?
I’ve explained this enough here, and over in Discord. Now it’s time for you to read the automation docs, and try stuff out. I don’t think repeating myself is going to help.
