Trying to achieve the following:
- if TV is ON and PIR detects movement turn on a light in dim mode (and keep it on)
- if TV is OFF and PIR detects movement turn on a light in bright mode
of course if no PIR movement then lights stays off
Possible, how?
Assuming you have some entity that can tell you if tv is on or off yes pretty easy to implement. Just using automations and a template for changing the brightness setting after light.turn_on is called.
trigger will be the PIR sensor detecting motion, action will be call the light.turn_on
service.
service: light.turn_on
data_template:
entity_id: light.lightname
brightness: '{% if is_state("entityid.tv", "on") %}255{% else %}100'
Something like that… its been awhile since ive looked at my home assistant configs so might be some errors in syntax there.
I should exchange 255 with 100, right? I mean if TV on 100, if off 255. Yes?
trying now
17-04-18 22:50:03 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: invalid template (TemplateSyntaxError: Unexpected end of template. Jinja was looking for the following tags: ‘endif’. The innermost block that needs to be closed is ‘if’.) for dictionary value @ data[‘action’][0][‘data_template’][‘brightness’]. Got None. (See /home/hass/.homeassistant/configuration.yaml, line 1278). Please check the docs at Automation - Home Assistant
some brackets to be changed?
I have no clue
Oh yep you need {% endif %} at the end, use the template editor from the dashboard to debug the template until it works.
like this?
brightness: ‘{% if is_state(‘media_player.yamaha_receiver’, ‘on’) %}120{% else %}255, {% endif %}’
(a comma after 255?)
trying now, result is
brightness: '255, ’
is the , and space correct to have?
no, I got it
brightness: ‘{% if is_state(‘media_player.yamaha_receiver’, ‘on’) %}120{% else %}255{% endif %}’
this
data_template:
entity_id: light.tv_standing_lamp
brightness: '{% if is_state('media_player.yamaha_receiver', 'on') %}120{% else %}255{% endif %}'
gives this error
17-04-18 23:14:52 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block mapping
in "/home/hass/.homeassistant/automation.yaml", line 580, column 9
expected <block end>, but found '<scalar>'
in "/home/hass/.homeassistant/automation.yaml", line 581, column 38
17-04-18 23:14:52 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/hass/.homeassistant/configuration.yaml: while parsing a block mapping
You must use double quotes around media_player.yamaha_receiver
and on
in the template
