Hi all,
I didn’t get an automation working.
Here is the code for it in yaml:
- alias: 'Benachrichtigung wenn Schwarze Tonne'
platform: state
entity_id: calendar.mullabfuhr
to: on
condition:
condition: template
value_template: '{{ "states.calendar.mullabfuhr.attributes.message" = "Erinnerung: Abfuhr schwarze Restmülltonne morgen ab 6 Uhr" }}'
service: notify.iphone
title: "Schwarze Tonne:"
message: "Rausbringen!"
I want to get a notification to my iphone if a calendar event is changing its state to on and based on the
message of the calendar i want to change the message of the notification. So basicly i try to check if the
value of states.calendar.mullabfuhr.attributes.message is equal to “Erinnerung: Abfuhr schwarze Restmülltonne morgen ab 6 Uhr”
But when I check the config, I get the following error:
Invalid config for [automation]: expected str for dictionary value @ data[‘trigger’][0][‘to’]. Got None
invalid template (TemplateSyntaxError: expected token ‘end of print statement’, got ‘=’) for dictionary value @ data[‘condition’][0][‘value_template’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘condition’]. Got None
required key not provided @ data[‘condition’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 12). Please check the docs at https://home-assistant.io/components/automation/
I’ve tried to use different " and ’ settings but nothing worked.
Can someone please help me?
Thanks.
