I’m trying to make an automation to start at 5:00 am an keep running the automation till 7:00 am between that time if a temperature is below 40ºC it turns on a switch, if not, does nothing, but if it turn on the switch it should be continuously check the temperatura till it reaches 40ºC after that it turn off the switch
i had this in node red but here I’m having a trouble make it run between that time because it let’s the temperature rise above 40ºC and I had to make another automation to force it to turn off.
can anyone help me to solved this
