Hi guys, got my first automation blueprint. It works (4 automation created and working) but in log I see
this error:
HA 2022.10.3
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:246
Integration: Automatizace (documentation, issues)
First occurred: 17:40:50 (1 occurrences)
Last logged: 17:40:50
Blueprint Control TRVs - generated invalid automation with inputs OrderedDict([('heating', 'input_boolean.livingroom_heating'), ('target_valves', 'climate.livingroom_valve_1')]): expected a dictionary for dictionary value @ data['action'][0]['else'][0]['target']. Got None expected a dictionary for dictionary value @ data['action'][0]['then'][0]['target']. Got None
And second minor problem is that if I create automation over this blueprint in web UI it not show up in automations tab(even page refresh not works, only restart HA), but if I open mobile app automations are there and it works correctly when I create automation same way in mobile app.
Same result and it destroyed all automations using this blueprint, only one persist
EDIT: I don’t know if you see that, but I want to be able select more than one TRV and only one input_boolean so entity_id doesn’t make sence cause I thing it’s only for one statement not an Array.
BTW I did create this automation manully at first time, then copy&paste and add blueprints attributes and input variables.
Then I think you are missing some blank spaces in some place…
I don’t have my computer now, so I will be limited to replicate exactly your blueprint, but when I try to create the same in the automation UI, I get this (it is incomplete, just to see the spaces on the actions):
Yes, that’s helped. I checked source in editor printing white chars and there’s not space/tab mix. But indent of rows below action section was probably wrong. Thanks
