I’ve had my automation setup for my Nest thermostats for awhile now to adjust the hvac_mode from heat_cool to heat and vice versa. Finally got into a warm spell and flipped back. Each time my automation tried to change the mode nothing happened. It would not modify the mode and would not modify the temperature. I could go into the HA overview and manually modify it there, but not via an automation. Debug shows it is sending the proper commands. If there is no mode change (regardless of the mode), the temperature is set correctly.
I saw a similar bug report that was fixed where setting hvac_mode to off fails and was resolved. My guess is there are further bugs with this integration or with Google API. Anyone else having this same problem or should I create a new bug report?
If there are no relevant errors in your log, have a look at the automation trace to see what is going on. The part of the config you have shared looks ok to me. Though you could just put both choose conditions at the top level rather than nesting them. Conditions are AND logic by default. Unless there are other choose options you have not shown.
My next steps are to do some testing and narrow down where the bug is at. Could be the API does not like to change the mode and set the temperature at the same time. I can break those down. Furthermore, I could work around the bug by just changing the automation to not modify the mode (which I know works just fine) and adjust temp max and min to keep them from triggering (what I was using hvac_mode for).
That worked. Appears there is a conflict in how climate.set_temperature is being used in the integration creating a lot of confusion. I guess that the API does now allow it, but HA/integration thinks it exists.
Hi there - I’m trying to set up my first automation and it relates to Nest Modes. Can you see what I’m doing wrong here? I want to be notified when the Nests are set to be in conflict with one another, especially if they are “running” in conflict (e.g. heat on downstairs, and cool on upstairs).
alias: Thermo Conflict
description: ""
- platform: state
entity_id: climate.downstairs
- platform: state
entity_id: climate.upstairs
condition:
- condition: template
value_template: >-
{{ states('climate.downstairs') != states('climate.upstairs')
- service: notify.email_notification
message: >-
White Downstairs is in {{ state_attr('climate.downstairs',
'hvac_mode') }} mode, while White Upstairs is in {{
state_attr('climate.upstairs', 'hvac_mode') }} mode. Please check
your HVAC system.
