I’m using a yeelight ceiling light with es-home firmware. So I have two device entities for normal light and night mode.
I also have a wall switch with a sensor. At the moment each time the wall switch is changed the ceiling light toggles the state.
I now want to specify that when it is after 23:00 an before sunrise or 6:00 the wall switch should toggle the night mode and between sunrise or 6:00 an 23:00 it should toggle the normal light.
I think this should work with a template but I have no clue how to set up this automation with a template.
can someone here help me set this up?
cheers and thanks for your possible help
for now I have this code snippet but it does not work …
- id: '1664105673904'
alias: Bad Decke
description: ''
- type: powered
platform: device
device_id: 385e97658204df06034ed9db90597d58
entity_id: binary_sensor.badezimmer_channel_2_input
domain: binary_sensor
- type: not_powered
platform: device
condition: []
- type: toggle
data_template:
entity_id: >
{%if (now().time().strftime("%H")| int > 6 ) and(now().time().strftime("%H")| int < 19 )%}
light.yeelight_bad_ceiling_light
{% else %}
light.yeelight_bad_night_light
{% endif %}
domain: light
mode: single
