Can you help me? I am doing something wrong.
I try to check the temperature (sensor aqara) at one hour, and if the result is less than 20 degrees, it should send a msg telegram (test).
It currently sends the message at the scheduled time, regardless of whether it is above or below 20 degrees.
- id: temp_dormitorio
alias: Comprobar Temperatura DORMITORIO
description: Si la temperatura del dormitorio es inferior a 20 grados, envía msg
por Telegram
- platform: numeric_state
entity_id: sensor.temperature_thpdormitorio
below: 20
- platform: time
at: '14:23:00'
condition: []
- service: telegram_bot.send_message
message: Prueba
This will send a message at 14:23 but only if the temperature is below 20.
por Telegram
- platform: time
at: '14:23:00'
condition:
- condition: numeric_state
below: 20
message: Prueba
Your automation sends a message when the time is 14:23 or if the temperature is below 20. That means even if the temperature is not below 20 you will still get a message at 14:23.
