Upgraded last night from 0.30 to 0.32.3 using the manual instructions for All-In-One (Getting started - Home Assistant). This is my first time updating HA and … has not gone well for me
After upgrading, things started falling apart. I received a message on the frontend that the automation component failed to initialize. From the log:
homeassistant.bootstrap: component automation failed to initialize
Played with my automation scripts a little to see if I could find an error with no success. This was all working on previous version of hass.
Relevant line in configuration.yaml looks like this:
automation: !include_dir_merge_list automation
automation directory currently only has one file: dooropen.yaml
dooropen.yaml:
alias: DoorOpen trigger: platform: state entity_id: binary_sensor.schlage_ecolink_dwzwave1_sensor_4_0 to: "on" action: service: notify.gmail data: title: "Someone is here" message: "Just sayin" hide_entity: true
Don’t know if it is related, but I am also seeing random Z-wave errors in the HA log. Doesn’t seem to effect the devices through hass, but I never saw these errors prior to upgrade:
16-11-14 10:51:40 homeassistant.components.sensor: Error while setting up platform zwave
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 148, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/zwave.py", line 37, in setup_platform
add_devices([ZWaveMultilevelSensor(value)])
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 289, in add_entities
).result()
File "/usr/lib/python3.4/concurrent/futures/_base.py", line 402, in result
return self.__get_result()
File "/usr/lib/python3.4/concurrent/futures/_base.py", line 354, in __get_result
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 304, in async_add_entities
yield from asyncio.gather(*tasks, loop=self.component.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 320, in _async_process_entity
new_entity, self, update_before_add=update_before_add
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 194, in async_add_entity
yield from entity.async_update_ha_state()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 225, in async_update_ha_state
device_attr = self.device_state_attributes
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 597, in device_state_attributes
battery_level = self._value.node.get_battery_level()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/command.py", line 284, in get_battery_level
for val in self.get_battery_levels():
File "/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/command.py", line 306, in get_battery_levels
type='Byte', readonly=True, writeonly=False)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/node.py", line 438, in get_values
for value in self.values:
RuntimeError: dictionary changed size during iteration
16-11-14 10:51:41 homeassistant.components.sensor: Error while setting up platform zwave
).result()
result = next(coro)
