I have a trigger with a template condition which fails sometimes and I have no clue why.
The template condition is for preventing false triggers by demanding that the previous state was active for at least 25 minutes
Sometimes it works but sometimes I get the following error:
Error: In ‘template’ condition: UndefinedError: ‘dict object’ has no attribute ‘from_state’
This occurs mostly after a long time home and then the automation triggers at sunset.
My complete automation:
alias: Lights on
- platform: state
entity_id: person.owner
to: home
- platform: sun
event: sunset
offset: '+00:05:00'
condition:
- condition: state
state: home
- condition: template
value_template: >-
{{ (now().timestamp() - trigger.from_state.last_changed.timestamp()) >
1500 }}
- condition: or
conditions:
- condition: sun
after: sunset
after_offset: '+00:05:00'
- condition: sun
before: sunrise
before_offset: '+01:00:00'
- service: homeassistant.turn_on
entity_id:
- light.lamp
transition: 10
Hope there’s a smart person around here somewhere😉.
trigger.from_state is only valid for a state trigger, and you also have a sun trigger. My guess is that you’re seeing the error when the sun trigger causes the automation to run. You can make a more complex condition or use a choose: to allow more flexibility, but I’d just make a separate automation for each trigger type.
Thank you guys for replying.
No state when the sun triggers sounds like the issue indeed.
I tried the “for” option before but that did not work.
I use Netgear presence for detecting when I’m coming home. Now sometimes it happens that in the middle of the night my home/not home status changes every 5 a 25 minutes for a while and then my lights go on downstairs.
That’s why I was trying to prevent this with the template condition.
Any other ideas to prevent my issue is highly appreciated!
