Consider a sensor (e.g., ambient light) that is sometimes offline (reasons unimportant).
You have automations with conditions that test that sensor.
When it’s offline, the automations stop at the condition-test, but what you want is for them to proceed when the sensor is offline/unavailable.
How can this be done?
Could it be solved by [adding a new feature where] the ‘condition’ block includes a parameter like ‘default_result: true
’ that will be returned if the specified device is unavailable?
Or, perhaps the desired result could be done with logic (paraphrased) as: “sensor-state if sensor not ‘unavailable’, else ‘true’”
