how to check if input_text is empty in automation - condition ?
{{ states('input_text.your_entity') == ' ' }}
return true
if the text field is empty.
Thx.
Can you show me how tu use this in automation?
condition:
- condition: template
value_template: "{{ states('input_text.your_entity') == ' ' }}"
That’s not empty that’s a space. Does it actually work?
You could also do:
value_template: "{{ states('input_text.your_entity')|length == 0 }}"
Now I have another question:)
How to empty input_text
in automation?
I tryed like this:
service: input_text.set_value
value: ' '
entity_id: input_text.mami_google_calendar_description
but input_text not empty I have space in it.
Flawlessly. But I think your solution is more elegant.
Did you set an initial value in your input_text config?
value: '' # that's two single quotes with no space.
Another question:
How to deselect (clear selection) in input_select in automation?
I don’t think you can clear it. You can only change it to one of the options. Maybe add an extra option “Nothing Selected”, or “Off”?
I am usingentity_select
like you say. I just wondering if there’s a way to deselect selection:)
Not that I know of.
I have a strange problem with automation and input_text.
In both cases automation goes trough option 2 with or without text in input_text.mami_google_calendar_description
here is automation:
alias: mimi_google_calendar
description: vpis v google koledar mami poÄŤutje
- platform: state
entity_id: input_boolean.mami_google_calendar_confirm
to: 'on'
condition: []
- choose:
- conditions:
value_template: >-
"{{ states('input_text.mami_google_calendar_description')|length
== 0 }}"
sequence:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: input_boolean.turn_off
data: {}
- conditions:
- condition: not
conditions:
value_template: >-
== 0 }}"
sequence:
- service: google.add_event
calendar_id: [email protected]
summary: '{{ states(''input_select.mami_google_calendar_select'') }}'
description: '{{ states(''input_text.mami_google_calendar_description'') }}'
end_date_time: >-
{{ states('input_datetime.mami_google_calendar_date') }}T{{
states('input_datetime.mami_google_calendar_time') }}Z
start_date_time: >-
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
data: {}
- service: input_select.select_option
option: izberi
entity_id: input_select.mami_google_calendar_select
- service: input_text.set_value
value: ''
default: []
mode: single
This is not correct. Do not quote multi-line templates
- conditions:
- condition: not
conditions:
value_template: >-
== 0 }}"
I can also be simplified to:
- conditions:
value_template: >
!= 0 }}
Only quote single line templates:
- conditions:
value_template: "{{ states('input_text.mami_google_calendar_description')|length != 0 }}"
You have done this in two places.
Now is working. thx
