Automation condition template based on trigger
Hello i’m trying to figure out how to template automation conditions. The conditions should be based on the automation trigger. When i check the config i don’t see any errors. However the automation doesn’t fire. Can anyone help me out with this?
- alias: Stekker bed uit wanneer iemand vertrekt in de ochtend
   - platform: state
     entity_id: group.glenn
     to: 'not_home'
     for:
       seconds: 30
   - platform: state
     entity_id: group.ellen
     to: 'not_home'
     for:
       seconds: 30
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: sensor.partofday
        state: 'Ochtend'
      - condition: template
        value_template: >
          {% if trigger.entity_id == 'group.glenn' %}
            is_state('switch.bed_glenn', 'On')
          {% else %}
            is_state('switch.bed_ellen', 'On')
          {% endif %}
    - service: switch.turn_off
      data_template:
        entity_id: >
            switch.bed_glenn
          {% else %}
            switch.bed_ellen
          {% endif %}
    - service: notify.pushover
      data_template:
        message: >
            Stekker bed Glenn uitgeschakeld.
          {% else %}
          {% endif %}
I’m looking to get this part of the automation working. When I comment this out. Everything is working fine.
        value_template: >
          {% else %}
          {% endif %}
can’t really see what’s wrong.
Maybe try and change like this to remove trailing spaces as “true” is not the same as " true "
        value_template: >-
          {%- if trigger.entity_id == 'group.glenn' -%}
          {%- else -%}
          {%- endif -%}
Also conditions are “AND” by default so no need for:
  condition:
    condition: and
    conditions:
Unfortunately it’s not working…
Do I just change this?
condition:
    condition: and
    conditions:
with this
condition:
   - platform: state
     to: 'not_home'
     for:
       seconds: 30
   - platform: state
     to: 'not_home'
     for:
       seconds: 30
  condition:
    - condition: state
      state: 'Ochtend'
      value_template: >-
          {{is_state('switch.bed_glenn', 'On')}}
        {%- else -%}
          {{is_state('switch.bed_ellen', 'On')}}
        {%- endif -%}
      data_template:
        entity_id: >
            switch.bed_glenn
          {% else %}
            switch.bed_ellen
          {% endif %}
      data_template:
        message: >
          {% else %}
          {% endif %}
That’s what I have right now. Not working however.
think I’ve just fixed it in above script. You forgot the curly braces around is_state('switch.bed_glenn', 'On') so it would just output this string instead of true/false
Nope. It’s still not working. :frowning:
Try lowercase for ‘on’.
This fixed it!
