I have this condition with sunset/sunrise limits with an offset for sunrise of 45 minutes. This morning it validated the condition with below:
Executed: August 30, 2022 at 6:34:14 AM
Result:
wanted_time_before: '2022-08-30T18:33:03.916464+00:00'
wanted_time_after: '2022-08-30T05:33:47.101391+00:00'
result: false
So how does it return false on 6:34 when that is fitting right in the timerange it mentions here? Anyone suggestions?
but my real question is really: you see time executed and the wanted values before and after (copied from ‘trace’), isnt that a hint that somewhere those values are not properly compared?
OR the time before and after are not taking into account the timezone and those are GMT? then it would explain
Many reported incidents of “things aren’t triggering at the right time” are often due to how the system clock is configured for a virtual system. That’s why it’s useful to know about the environment in which Home Assistant is running.
fair enough. Except for this trace log and condition not doing what the variables values say, should no longer be tied to system clock… or am i missing some logic here?
Result type: string
2022-08-31 08:18:11.309541+00:00
2022-08-31 10:18:11.310229+02:00
2022-08-31 10:18:11.310379+02:00
2022-08-31 10:18:11.311426+02:00
UTC
Europe/Amsterdam
CEST
so it would help to have the automation trace add timezone with the timestamp, then all should be clearer to debug and fix.
or have daylightsavings adapted?
