So I exluded my Zoos ZEN32 Scene conroller from the ZwaveJS integration so I could do a firmware update on the device. It excluded from the network no problem BUT it broke my automation conifg.
I am using the Zwavejs add on with homeassistantOS.
I tried reflashing my odroid and restoring from a backup but the problem persists.
The firmware on the scene controller was a beta and I’m using an older nortek HUSBZB-1 But Im thinking this is an integration issue with Zwavejs. I made a pull request here.
I am out of my element here and my whole house runs on home assistant. Any thoughts and ideas would be much appreaciated. Thanks for taking the time to read.
These logs shows up:
Logger: homeassistant.config
Source: components/zwave_js/helpers.py:283
First occurred: 13:08:20 (1 occurrences)
Last logged: 13:08:20
Unknown error calling automation config validator
File "/usr/src/homeassistant/homeassistant/config.py", line 833, in async_process_component_config
return await config_validator.async_validate_config( # type: ignore
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 129, in async_validate_config
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 106, in _try_async_validate_config_item
config = await async_validate_config_item(hass, config, full_config)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 74, in async_validate_config_item
config[CONF_TRIGGER] = await async_validate_trigger_config(
File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 50, in async_validate_trigger_config
conf = await platform.async_validate_trigger_config(hass, conf)
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 26, in async_validate_trigger_config
return await getattr(platform, "async_validate_trigger_config")(hass, config)
File "/usr/src/homeassistant/homeassistant/components/zwave_js/device_trigger.py", line 220, in async_validate_trigger_config
if async_is_device_config_entry_not_loaded(hass, config[CONF_DEVICE_ID]):
File "/usr/src/homeassistant/homeassistant/components/zwave_js/helpers.py", line 283, in async_is_device_config_entry_not_loaded
assert device
AssertionError
Logger: homeassistant.setup
Source: setup.py:159
First occurred: 13:08:21 (1 occurrences)
Last logged: 13:08:21
Unable to set up dependencies of default_config. Setup failed for dependencies: automation
Source: setup.py:179
First occurred: 13:08:20 (2 occurrences)
Setup failed for automation: Invalid config.
Setup failed for default_config: Could not set up all dependencies.
This is my setup:
System Health
version: core-2021.9.6
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.6
os_name: Linux
os_version: 5.10.53
arch: aarch64
timezone: America/Regina
GitHub API: ok
Github API Calls Remaining: 4916
Installed Version: 1.15.2
Stage: running
Available Repositories: 941
Installed Repositories: 6
logged_in: true
subscription_expiration: 19 September 2021, 18:00
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: false
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 6.2
update_channel: stable
supervisor_version: supervisor-2021.09.0
docker_version: 20.10.6
disk_total: 113.9 GB
disk_used: 7.0 GB
healthy: true
supported: true
board: odroid-n2
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.5.1), Mosquitto broker (6.0.1), Home Assistant Google Drive Backup (0.105.1), Hyperion.NG (2.0.0-alpha.9), File editor (5.3.3), AdGuard Home (4.1.9), Terminal & SSH (9.1.3), MariaDB (2.4.0), Spotify Connect (0.9.1), Z-Wave JS (0.1.39)
dashboards: 4
resources: 5
mode: storage
api_endpoint_reachable: ok
