Hi all,
I have a few shelly device (1L or 1pm) that I would like to automate single/double click and long press.
Unfortunately, my double click doesn’t seem to be triggered. (I am using a single pole diy to momentary), may be I forget something in the setting. I could probably use a counter instead, that would reset itself after x time. But before that, I have another issue or let’s say concern.
At first, I would like to use the single click vs long click.
Concern: the connected lights turn on/off with the single or long click as the relay gets triggered by switch as it’s programmed.
Should I change something in the setting or should I use automation to do it all (meaning turned off the relay light if it’s a long press ?)
