Automation Delay template convert seconds to HH:MM:SS format
For a random delay in an automation I am using the following template:
{{ range(5, 25)|random|multiply(60) }}
This gives me this error:
delay template: offset 2100.0 should be format 'HH:MM' or 'HH:MM:SS'
What function could I use to change seconds to HH:MM:SS ?
Append an int filter to the template.
It appears to be generating a float value and delay won’t accept that. I assume you are using this template with seconds: ( or minutes: ) and not directly with delay:
Example:
- delay:
    seconds: "{{ range(5, 25)|random|multiply(60)|int }}"
Why not just create the delay in the required format (edit as @123 suggested):
'00:{{ range(5, 25)|random|int }}:00'
The lack of the int filter was the problem. FWIW, this also works:
- delay: "{{ range(5, 25)|random|multiply(60)|int }}"
Although your suggestion is probably clearer.
BTW, range(5, 25) returns a value between 5 and 24, not 5 and 25. If you really want the upper end to be 25, then you need to specify 26 as the second value:
- delay: "{{ range(5, 25+1)|random|multiply(60)|int }}"
