i am trying to make a automation, that brightens and dims lights after sunset after movement is detected by xiaomi body sensor
The lights are turned on by another automation when the sun is down, at 30%
I want them to 90% for 3 minutes, and then return to 30% again
I am using xiaomi body sensors for this
I currently use this, brightening to 90% is ok, but they dont go back to 30 after 3 minutes
- alias: "Garage links On"
- platform: state
entity_id: binary_sensor.motion_garage_occupancy
to: 'on'
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
- service: homeassistant.turn_on
entity_id: light.garage_links
brightness_pct: '90'
transition: 3
# - service: notify.notify
# data:
# message: Office Motion Light On
- alias: "Garage links Off"
- platform: state
to: 'off'
for:
minutes: 3
- service: homeassistant.turn_off
brightness_pct: '30'
transition: 3
# data:
# message: Office Motion Light Off
jocnnor
(Jim O'Connor)
March 22, 2020, 9:09pm
2
transition: 3
You want homeassistant.turn_on if you want to set brightness.
so like this?
- platform: state
to: 'on'
condition:
- condition: state
entity_id: sun.sun
transition: 3
# data:
- platform: state
to: 'off'
for:
minutes: 3
brightness_pct: '35'
transition: 3
# data:
i use this to turn on/off a group of lights outside:
- id: turn_outside_lights_on
alias: buitenlampen_aan_zonsondergang
- platform: sun
event: sunset
- platform: sun
event: sunrise
service_template: "{% if trigger.event == 'sunset' %}\n homeassistant.turn_on\n\
{% elif trigger.event == 'sunrise' %}\n homeassistant.turn_off\n{% endif %}"
entity_id: light.buitenlampen_aan_zonsondergang
transition: 3
Menelao
(Roberto)
March 24, 2020, 11:43am
5
The turn_off service does not have the attribute brightness_pct, if you use it you sould have an error in the log.
Every time you need to change the brightness you need to call turn_on
I am not using that anymore?
Both are turn_on I think?
jocnnor
(Jim O'Connor)
March 24, 2020, 1:44pm
7
Lets fix your templates.
https://yaml-multiline.info/
That website will show you yaml multi line formatting with examples.
This is much easier to read using the folded style scalar.
service_template: >
{% endif %}
Or if you want it to be more compact…
service_template: "homeassistant.turn_{{ 'on' if trigger.event == 'sunset' else 'off' }}"
But you still have the same problem. Brightness percent wont be used when it’s sunrise.
Are the lights just turning off after 3 minutes? Because that’s what should be happening.
Yes, basically they should turn off after a set time
That’s easier I think then turning off after no movement in 5 minutes?
jocnnor
(Jim O'Connor)
March 24, 2020, 7:16pm
9
Yeah. We just aren’t sure what, if anything, is still the problem. It was originally about dimming some lights, but then you posted “i use this to turn off a group of oustide lights”. Wasn’t sure if there was some problem with that or not.
Basically it’s this:
A group of lights, garden, garage etc is turned on at sunset, and turned off at sunrise
At the garage door, in the garden, at my garden shed, I have various xiaomi body sensors. If triggered, the lights at that place should brighten to 90%.
right now this code is not turning off the lights at sunrise?
- platform: sun
event: sunset
- platform: sun
event: sunrise
service_template: >
{% endif %}
jocnnor
(Jim O'Connor)
March 26, 2020, 1:48pm
12
service_template indentation is not correct. Could just be a copy/paste error…but I don’t see any other problems with it.
- platform: sun
event: sunset
- platform: sun
event: sunrise
service_template: >
{% endif %}
123
(Taras)
March 26, 2020, 2:16pm
13
Try this:
- platform: sun
event: sunset
- platform: sun
event: sunrise
service_template: "light.turn_{{ 'on' if trigger.event == 'sunset' else 'off' }}"
