Hi
I have this automation that turns on some lights when activated by a motion sensor and turns off the lights again when no motion is detected for 5 minutes, this work. But now I have added some more lights that is turned on by a sensor on my fridge, I want these new lights to turn off the same time as the first once - 5 minutes after motion is detected. But it does not work. The 2 zha lightgroups turns on and the first of them turns off. If i run the action from the Run command in the visual editor it works. There is nothing in the log - or i’m not looking in the right place. The code is as simple as below.
- conditions:
- "{{ trigger.to_state.state == 'off' }}"
sequence:
- service: light.turn_off
data: {}
entity_id:
- light.silicon_labs_ezsp_kokken_lys_gruppe
data: {}
entity_id: light.silicon_labs_ezsp_kokkenbord_lysgruppe
