Automation does not trigger input_boolean
I’m trying to define a template for automation to enable / disable between two dates and times. It is an automation to activate a conditional mode.
For this I have defined the time_date sensor:
  • platform: time_date
    display_options:
    • ‘time’
    • ‘date’
    • ‘date_time’
    • ‘date_time_utc’
    • ‘date_time_iso’
    • ‘time_date’
    • ‘time_utc’
    • ‘beat’
The imput_boolean:
input_boolean:
futbol_match:
initial: off
And finally the imput_datetime
input_datetime:
futbol_match_on:
has_date: true
has_time: true
futbol_match_off:
has_date: true
has_time: true
And in automation, I’m trying to use this formula, but it doesn’t work. I can’t find the formula to automatically turn it on and off. Can you help me, please? Thank you
‘{{ states(’‘sensor.date_time’’) == (state_attr(’‘input_datetime.futbol_match_on’’,
‘‘timestamp’’) | int | timestamp_custom(’’%H:%M’’, True)) }}’
and this automation
  • id: ‘Match On’
    alias: Match On
    description: ‘’
    • platform: template
      value_template: ‘{{ states(’‘sensor.date_time’’) == (state_attr(’‘input_datetime.futbol_match_on’’,
      condition: []
    • data: {}
      entity_id: input_boolean.futbol_match
      service: input_boolean.turn_on
First you need to format your code properly for display in the forum. If you don’t we can’t see any syntax errors in the code. put three back ticks (```) before and after your code sections.
