Automation does not work - wrong condition declaration
Dear All,
I am trying to write an automation. My intention is that:
on specific time, if IR trigger fires (I am using sonoff bridge flashed tasmota), HA will call ringtone on Xiaomi hub integrated on HA. My config below but seem wrong for it automation does not work
Can anyone help me to show what’s wrong with my code?
- alias: Barking high volume
    - platform: mqtt
      topic: tele/sonoffrf/RESULT
    condition: and
    conditions:
      - condition: template
        value_template: "{{ trigger.payload_json.RfReceived.Data == '7F176A' }}"
      - condition: time
        after: '23:30:00'
        before: '05:30:00'
    service: xiaomi_aqara.play_ringtone
      gw_mac: XXXXXXXXXXXXXX
      ringtone_id: 8
      ringtone_vol: 60
You need two time conditions, with “or” between them.
Time can’t be both after 23:30 and before 05:30 at the same time.
Surely this is a trigger? Not a condition.
Dear Olen,
Many thanks for your suggestion. What I need is let us fire between 23:30 today and 05:30 tomorrow.
I will try to correct it
Hi nickrout,
Many thanks for your comment.
Acctually, without “condition: time”, the automation work well, like this:
- alias: RM1 button A
    - platform: mqtt
      value_template: "{{ trigger.payload_json.RfReceived.Data == '65F708' }}"
    - service: switch.turn_on
      entity_id: switch.dining_light
You would need something like this:
    condition: or
    conditions:
      - condition: time
        after: '23:30:00'
      - condition: time
        before: '05:30:00'
All conditions as “and” if you do not specify “or”.
Dear Olen,
Many thanks for your help.
However, I am confused: How to pu the rest condition:
      value_template: "{{ trigger.payload_json.RfReceived.Data == '0620A9' }}"
    - platform: mqtt
    - condition: or
      conditions:
        - condition: time
          after: '23:30:00'
        - condition: time
          before: '05:30:00'
      ringtone_id: 8
      ringtone_vol: 60
Dear mf_socialMarc :uk:
Many thanks for your help. Actually, I do not know these coding for I am amateur user. Just find, read and copy, paste and test.
I will try and let you know result.
Minh Chau
Hi https://community.home-assistant.io/u/mf_social,
I tried your solution yesterday and it work!
Many thanks for your help!
Minh Chau
Dear mf_social,
I am trying this as well but it does not work (Another automation, not the once you fixed)
My idea is that:
When the IR fires and then door sensor fires (both via Sonoff Bridge Tamota), then, home assistant will turn on a switch.
Note: door sensor has no state (such as opened or closed) information, just firing once door opens.
My code are below, can you help me once again?
- alias: something
    - platform: mqtt
    - condition: and
      conditions:
          value_template: "{{ trigger.payload_json.RfReceived.Data == '4D968E' }}"
     entity_id: switch.center_light
Again, this is a condition that cannot be fulfilled.
You will not receive both of these values in the same packet.
You probably need to make some template sensors based on the mqtt packets, and check the state of the sensors instead of the mqtt payload directly.
