I’m new to all of this and having troubles with a simple automation to switch the light on in the hallway when opening the door. It does nothing… I use aqara door sensors with deconz zigbee integration and SonoffLAN integration with Sonoff smart switches.
- id: '1606825601890'
alias: Licht aan bij deur openen
- platform: state
entity_id: binary_sensor.deur_naar_gang
to: 'open'
- service: switch.turn_on
entity_id: switch.sonoff_voordeur
I guess your state is wrong. binary sensors normally have the state on/off
you can check it in the developer tool section
I didn’t know that
Just checked in developer tools and the state is indeed on or off. I’ll test it and let you know!
I adjusted the state to on or off but still nothing happens. What am i not seeing/forgetting?
- platform: state
to: 'on'
Anything in your logs ? I assume you reloaded the automations ?
Automations are reloaded. In my logs i do not see anything about the automation, it’s like it’s not even there.
Is the automation enabled? Do you see it in Developer Tools -> States?
How do you enable an automation
? I can’t find it under states…
You should see all your automation in the states page if you filter by typing automations, if you click on the i next to the entity name, the pop up as shown appears, the switch on there enables/disables it
Nope no automation in there…
I have this set in my configuration file, is that correct?
automation: !include_dir_merge_list automations.yaml
If you only have one automations.yaml, try
Assume you automations.yaml
is saved in same directory as configuration.yaml
I think what you have is if you have an automations directory and multi automation yaml files in there:
automation: !include_dir_merge_list automations/
Yep that was it! I now understand when you have to put !include_dir_merge_list
and when not. After i changed it, the automation appears under Developer > States.
I’ll test the automation when i get home and let you know if it works.
The automation works now! Thanks everyone for the advice
