I have an automation what i want to starts after a state of sun and after a time.
But it doesnt trigger after the time.
Here is my example.
What is wrong at it?
If I read it correctly your automation does the following:
When the sun goes below the horizon and the tracker_lw group is home and it’s after 18:00h then the light turns on.
If the sun goes below the horizon when tracker_lw or after 18:00h nothing happens.
Is that what you intended?
Not sure what you mean by ‘If i restart this automation after the selected time’ - the trigger is the value of the elevation going below -1.0.
Only at the point in time that value changes to less than -1.0 the conditions are checked.
But i thought that he checks the automation until all conditions are good to launch?
So if sunset before 1800 nothing happends, after it is 1800he will launch
You are using a trigger based on the sunset but it’s actually a condition for what you want to achieve. There are several ways do solve this; You should add sunset to the conditions and use a time trigger which will check every xx seconds or minutes if the conditions are true (I think this is what you expected to happen).
platform: time
minutes: '/1'
But you can also use multiple automations for example one based on arriving home with sun and time as a condition, one based on sunset with being home and time as a condition and one based on time with being home and sunset as a condition.
