Is there a bug in the Automation Editor, when using the Trigger > Template you cannot type a value template?
Yeah, I get the same problem in 0.95.1.
Don’t know what the problem is though…
I can confirm the same issue on 0.96.5.
Repro:
- Go to Automation editor
- Add new Condition
- Select Condition Type = Template
- Fail your attempt to type anything into the Template line
Yeah, this has been a known issue since at least 0.76.0.
Here is the bug report on GitHub, you can add your findings there or subscribe to be notified if/when it gets fixed: https://github.com/home-assistant/home-assistant-polymer/issues/1601
