Hey guys, maybe this is a stupid question but something I noticed yesterday…
Within some automations I use for trigger the state of that automation changing from off to on (i.e. when I leave house I switch off some automations and switch them back on when I return). This was working some months before, when I returned home the automation was enabled and actions (if needed) executed. Yesterday I noticed that it doesn’t work any more with this sort of trigger (so, when I return home, the automation itself is enabled, but no actions are run).
Has something changed in meantime, does anyone have any ideas? Thanks!
(sorry if wrong group, I will relocate)
Turning automation on/off is generally a bad practice. You rather add conditions in the automations, so that they only run when you are home/away whatever.
Also you’d need to post some code of the non-triggering automations in order to get help. Ha changes so fast and drastically, could be 100s of reason why what worked months before doesn’t work now.
Thanks for the answer.
Why is it a bad practice? I generally used it on simple ambient lights, switch on-switch off situations. And since it worked well I didn’t feel the need to make it any more complex.
There’s no code to copy, as I did it in visual editor.
If I don’t find a simple solution, I will rework it some other way.
Thanks for the effort!
