I currently use UNIFI to discover devices. Every HA device I label as ha_device_name. I would like to create a single automation for all device_tracker.ha_… I know automations do not currently support wildcards in the entity_id filed. Anybody have any ideas how I can make this happen?
What are you trying to achieve? What’s the goal here?
Notification when a device goes offline(not_home) and comes back online(home) and I don’t want to keep updating the automation when I add a new home automation device. Just name it ha_device_name in unifi and it gets added to the automation.
Then yes with some templating logic to filter out only entity IDs starting device_tracker.ha_
Probably something like
{% if 'device_tracker.ha_' in entity_id and old_state == 'unavailable' %}
{% endif %}
No bueno.
- platform: state
entity_id: >
{% endif %}
to: 'home'
for:
minutes: 5
You will have to use that template in a template trigger, not a state trigger.
easy enough.
template trigger
- alias: '[Home Automation] Device Status Online'
platform: template
value_template: >
{% if 'device_tracker.ha_' in entity_id and old_state == 'not_home' and new_state == 'home' %} ...
{% endif %}
for: 00:05:00
- service: notify.mobile_app_michael_phone
data_template:
title: 'Device {{ trigger.to_state.name }} is'
message: >
'{{ trigger.to_state.state }}'
You need an event trigger, with that template in the condition, sorry for not being explicit about how that works.
Something like trigger every 5 mins?
No, an actual event
trigger, to use with the state_changed
event…
automation:
- alias: Ping me
- platform: event
event_type: state_changed
condition:
- condition: template
value_template: "{{ 'device_tracker.ha_' in entity_id and old_state == 'unavailable' }}"
(write the actions)
Tested the following and no go. Nothing in the logs and automation does not show it fired. Might see if I can setup something with appdaemon.
Device name - device_tracker.ha_lr_broadlink
- platform: event
condition:
value_template: "{{ 'device_tracker.ha_' in entity_id }}"
data_template:
message: >
I realise this thread is quite old, but I’ve just been fiddling with this today and got it to work, so thought I’d share for anyone else who comes across the thread.
The problem with the above is that the trigger is an event, so you can’t refer directly to entity_id in the condition. Instead you have to refer to trigger.event.data.entity_id
So mdleal’s code becomes:
- platform: event
condition:
value_template: "{{ 'device_tracker.ha_' in trigger.event.data.entity_id }}"
(etc...)
You’d also have to do similar in the action, so trigger.event.data.new_state.state instead of trigger.to_state.state
