Automation entity id does not rename anymore based on alias
Example automation:
- id: '011'
  alias: Toilet door open > Toilet lamp toggle off
This results in entity id automation.toilet_door_open_toilet_lamp_toggle_off
Before 0.105 you could change the alias, and this would automatically change the entity id. In other words, alias and entity_id were in sync.
After 0.105 this sync is gone. At least, this only applies when you are using ‘id’, which I do/did.
I guess ‘the sync’ is impossible from now on?
Bumper de bump
use this simple 30sec work around
