Automation error assistance
Please give me some pointers. I have searched the forums and see that typical errors are indentation or using state instead of to, but I can’t find these errors in my code.
configuration.yaml:
homeassistant:
  packages: !include_dir_named packages
packages/automation/test_notification.yaml:
automation:
    platform: state
    entity_id: device_tracker.stian_phone
    to: 'home'
    - service: notify.push
        message: Stian is home
Error:
Oct 13 21:46:30 ha hass[28449]: Failed config
Oct 13 21:46:30 ha hass[28449]:   automation:
Oct 13 21:46:30 ha hass[28449]:     - action: [source /opt/ha/cfg/packages/automation/test_notification.yaml:14]
Oct 13 21:46:30 ha hass[28449]:         - data: [source /opt/ha/cfg/packages/automation/test_notification.yaml:16]
Oct 13 21:46:30 ha hass[28449]:             message: Stian is home
Oct 13 21:46:30 ha hass[28449]:           service: notify.push
Oct 13 21:46:30 ha hass[28449]:       trigger: [source /opt/ha/cfg/packages/automation/test_notification.yaml:10]
Oct 13 21:46:30 ha hass[28449]:         platform: state
Oct 13 21:46:30 ha hass[28449]:         entity_id: device_tracker.stian_phone
Oct 13 21:46:30 ha hass[28449]:         to: home
Oct 13 21:46:30 ha hass[28449]: Successful config (partial)
Oct 13 21:46:30 ha hass[28449]:     - action: ?
Oct 13 21:46:30 ha hass[28449]:       hide_entity: False
Oct 13 21:46:30 ha hass[28449]:       trigger: ?
Oct 13 21:46:30 ha hass[28449]:         - platform: state
Oct 13 21:46:30 ha hass[28449]:           entity_id: ?
Oct 13 21:46:30 ha hass[28449]:             - device_tracker.stian_phone
Can you try this:
- alias: 'Stian is Home'
    platform: state
    to: 'home'
Thanks. I assume you mean including the automation keyword. I will also post the rest of the file.
script:
  test_notification:
    alias: Test notification
    sequence:
        message: Testing push notifications
automation:
      platform: state
      to: 'home'
I still get errors:
2017-10-14 12:35:21 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: required key not provided @ data['action']. Got None
required key not provided @ data['trigger']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
Failed config
  automation:
    - action: [source /opt/ha/cfg/packages/automation/test_notification.yaml:15]
        - data: [source /opt/ha/cfg/packages/automation/test_notification.yaml:17]
      alias: Stian is Home
      trigger: [source /opt/ha/cfg/packages/automation/test_notification.yaml:11]
        platform: state
        to: home
  automation:
    - action: ?
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
          to: home
Maybe using appdaemon would be easier, but I hoped to learn to use HA’s built-in automations for simple stuff.
My feeling is that the problem lies here:
Maybe try it first the normal way. Or use the Automation config Tool in the ui.
What about?
automation:
      platform: state
      to: 'home'
I have the same packages include in my configuration and it works.
Oct 14 17:40:40 ha hass[12769]: 2017-10-14 17:40:40 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: required key not provided @ data['action']. Got None
Oct 14 17:40:40 ha hass[12769]: required key not provided @ data['trigger']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
Oct 14 17:40:40 ha hass[12769]: Failed config
Oct 14 17:40:40 ha hass[12769]:   automation:
Oct 14 17:40:40 ha hass[12769]:     - action: [source /opt/ha/cfg/packages/automation/test_notification.yaml:15]
Oct 14 17:40:40 ha hass[12769]:         - data: [source /opt/ha/cfg/packages/automation/test_notification.yaml:17]
Oct 14 17:40:40 ha hass[12769]:             message: Stian is home
Oct 14 17:40:40 ha hass[12769]:           service: notify.push
Oct 14 17:40:40 ha hass[12769]:       alias: Stian is Home
Oct 14 17:40:40 ha hass[12769]:       trigger: [source /opt/ha/cfg/packages/automation/test_notification.yaml:11]
Oct 14 17:40:40 ha hass[12769]:         platform: state
Oct 14 17:40:40 ha hass[12769]:         entity_id: device_tracker.stian_phone
Oct 14 17:40:40 ha hass[12769]:         to: home
Oct 14 17:40:40 ha hass[12769]: Successful config (partial)
Oct 14 17:40:40 ha hass[12769]:     - action: ?
Oct 14 17:40:40 ha hass[12769]:       hide_entity: False
Oct 14 17:40:40 ha hass[12769]:       trigger: ?
Oct 14 17:40:40 ha hass[12769]:         - platform: state
Oct 14 17:40:40 ha hass[12769]:           entity_id: ?
Oct 14 17:40:40 ha hass[12769]:             - device_tracker.stian_phone
I would like to keep the structure where I can group related configuration for different components in the same file, but I’ll try the Automation config tool, thanks!
i mean it more for debugging :wink:
I think for different grouping you need to use different formats.
When i read this: Splitting up the configuration - Home Assistant
it seems that there are several different version availble which require each a different layout.
I can confirm that the automation i posted works for me in an FILENAME.yaml with this:
!include_dir_merge_list automations/
Uhm, I think you are right. I guess I confused what i planned to do, and what I actually did :joy: Thank you all, I’ll try again :slight_smile:
Just a thought, can you move your test_notification.yaml directly in the packages folder?
Without the automation subfolder.
I think the packages implementation is a little buggy, because reload customizing, groups, scripts and automations never works with packages.
I always have to restart HA on changes.
Nice! :slight_smile:
Can you please test it with another name for the subfolder?
If the name “automation” raises this error, it’s time to file an issue.
That seemed to do the trick! I go back on my previous statement, I followed the setup from https://github.com/skalavala/smarthome.
Moving it to ‘a’ instead of ‘automation’ worked, so it seems to be the name as you suggest.
Filed an issue.
