Automation error key not provided
I get this error on my automation.
I copied the code from a github repository so i don’t know why on my HA it doesn’t work,
Invalid config for [automation]: required key not provided @ data[‘action’]. Got None required key not provided @ data[‘trigger’]. Got None. (See ?, line ?)
automation:
  - alias: Trash Pickup Day Changed
    initial_state: true
      - platform: state
        entity_id: input_select.trash_pickup_day
      - service: mqtt.publish
        data_template:
          topic: "/home/trashpickupday"
          retain: true
          payload: '{{ states.input_select.trash_pickup_day.state }}'
Did you create the input_select?
Yes they all exist
How many “automation:” entries do you have in your config?
Other than that it looks like it should all be ok.
I splitted my yaml files by packages like examples found online from another user.
each yaml is inside a folder called packages in the root dir config.
So for each yaml file i’ve a new define for
automation:
group:
… Etc…
Why only automation: doesn’t work?
Probably because your !include statement for your automations yaml files is not correct.
I don’t use packages but I know when using includes you can’t have the “automations:” line at the top of your yamls … that comes from the include line in config… it should just start with your first automation.
    initial_state: true
      - platform: state
        data_template:
I dont think that is correct.
As long as your packages are defined properly you can have (and actually need) the automation: section in your package yaml file.
To the OP - post your configuration yaml and also post the first few lines of your automations yaml.
Is OP using actual packages or just splitting it and calling it a package?
Like I said and the docs show in the examples…remove the first line that says “automation:”
If he was splitting it up and calling it a package, the error would point to the line that contained
His error has
There could be a number of reasons why this is happening. He really needs to post his config.
