Automation error with light brightness_pct
I have for some time been trying to set up automations for my lights (tradfri) with different brightness based on time. I have set up different automations with time conditionals for after 07:00:00 before 23:59:59 and after 00:00:00 before 07:59:59 but when I insert brightness_pct: (value) on a line above the entity_I’d in the service data field the automation stops working. Without brightness it works as it is supposed to.
I have experienced this problem for a long time and thought it might be solved in future releases, but since it is still bothering me it looks like I have to add to the pile of posts in the forum.
I know there are scripts and templates that solves what I’m trying to achieve, but I am only using the automation ui. And want to continue doing so in order to keep automations easily maintainable.
Could you post a screen shot of what the action looks like in the automation editor when you try to add brightness_pct?
Well, it looks ok to me. When you try this, where/when do you see errors? Or do you not see errors and it just doesn’t work? If you’re able to save the automation with this, can you see what it looks like in the yaml file, and possibly post that? I don’t use the automation editor, so not sure why what you show doesn’t work.
There are no errors. It just does not work.
Then you should probably edit the yaml file. Let me know if you need help with that.
I tried to make sure that I did not make false claims and tried to set up yet another automation.
Usuallly it causes a non working set of automations when I combine time conditional and brightness_pct, but to my surprise my last automation “Lys toalett night” did not mess up and the automation "Lys toalett day is still working.
But there are three other sets of day and night automations that does not work, unless i remove the brightness_pct. (It also beaves the same way with the regular brightness 0-255)
I also noticed that the ui-editor reformats values with inconsistent encapsulation. Look at all locations of time and notice that some have ’ while other does not. I went through the file and placed ’ on all occourences of time, but after having editet an automation in the ui it all went back to the inconsistent state.
I have pasted my whole automations.yaml here.
- id: '1548785885000'
  alias: Lys plantelys off
  - at: '21:00:00'
    platform: time
  condition: []
  - data:
      entity_id: light.plantelys
    service: light.turn_off
- id: '1548787329983'
  alias: Lys plantelys on
  - at: 08:00:00
    platform: time
  condition: []
  - data:
    service: light.turn_on
- id: '1548787451454'
  alias: Lys terrasse off
  - at: 00:00:00
    platform: time
  condition: []
  - data:
      entity_id: light.terrasse
- id: '1548787611548'
  alias: Lys terrasse on
  - event: sunset
    platform: sun
  condition: []
  - data:
      entity_id: light_terrasse
- id: '1548787710871'
  alias: Lys hage off
  - event: sunrise
    platform: sun
  condition: []
  - data:
      entity_id: switch.lys_hage
    service: switch.turn_off
- id: '1548787754899'
  alias: Lys hage on
  - event: sunset
    platform: sun
  condition: []
  - data:
    service: switch.turn_on
- id: '1548787839196'
  alias: Lys veranda on
  - entity_id: binary_sensor.pir_veranda
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: switch.lys_veranda
- id: '1548787891801'
  alias: Lys veranda off
    for: 00:05:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548788131090'
  alias: Lys entre on
  - entity_id: binary_sensor.pir_entre
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: light.entre
- id: '1548788215043'
  alias: Lys entre off
    for: 00:02:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548788618767'
  alias: Lys bua off
  - entity_id: binary_sensor.pir_bua
    for: 00:15:00
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: light.bua
- id: '1548795677739'
  alias: Lys bua on
    platform: state
    to: 'on'
  condition: []
  - data:
- id: '1548795749589'
  alias: Lys aquarium off
  - at: '23:00:00'
    platform: time
  condition: []
  - data:
      entity_id: switch.lys_aquarium
- id: '1548795820146'
  alias: Lys aquarium on
  - at: '12:00:00'
    platform: time
  condition: []
  - data:
- id: '1548795943113'
  alias: Lys kitchen on 7-23
  - entity_id: binary_sensor.pir_kitchen
    platform: state
    to: 'on'
  condition:
  - after: 07:00:00
    before: '22:59:59'
    condition: time
  - data:
      brightness_pct: 100
      entity_id: light.kitchen
- id: '1548796005176'
  alias: Lys kitchen off
    for: 00:15:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548796266933'
  alias: Lys gang on 00-07
  - entity_id: binary_sensor.pir_gang
    platform: state
    to: 'on'
  condition:
  - after: 00:00:00
    before: 06:59:59
    condition: time
  - data:
      brightness_pct: 10
      entity_id: light.gang
- id: '1548796332064'
  alias: Lys gang off
    for: 00:05:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548796401433'
  alias: Lys spisestue on 7-23
  - entity_id: binary_sensor.pir_stueost
    platform: state
    to: 'on'
  condition:
  - after: 07:00:00
    before: '23:00:00'
    condition: time
  - data:
      brightness_pct: 100
      entity_id: light.spisestue
- id: '1548796464197'
  alias: Lys spsiestue off
    for: 00:30:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548796566142'
  alias: Lys bod on
  - entity_id: binary_sensor.pir_bod
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: light.bod
- id: '1548796621769'
  alias: Lys bod off
    for: 00:02:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548796686594'
  alias: Lys sauna on
  - entity_id: switch.ovn_sauna
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: light.sauna
- id: '1548796746841'
  alias: Lys sauna off
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548796819052'
  alias: Sauna auto off
    for: 04:00:00
    platform: state
    to: 'on'
  condition: []
  - data:
- id: '1548844649466'
  alias: Lys toalett on
  - entity_id: binary_sensor.pir_toalett
    platform: state
    to: 'on'
  condition:
  - after: 08:00:00
    before: '23:59:59'
    condition: time
  - data:
      brightness_pct: 100
      entity_id: light.toalett
- id: '1548844718862'
  alias: Lys toalett off
    for: 00:05:00
    platform: state
    to: 'off'
  condition: []
  - data:
- id: '1548899908163'
  alias: Lys gang on 07-24
    platform: state
    to: 'on'
  condition:
  - after: 07:00:00
    before: '23:59:59'
    condition: time
  - data:
      brightness_pct: 100
- id: '1548900953061'
  alias: Lys spisestue 23-7
    platform: state
    to: 'on'
  condition:
  - after: '23:00:00'
    before: 06:59:59
    condition: time
  - data:
- id: '1548901107723'
  alias: Lys kitchen 23-7
    platform: state
    to: 'on'
  condition:
  - after: '23:00:00'
    before: 06:59:59
    condition: time
  - data:
      brightness_pct: 10
Again, can’t comment on how well (or not) the automation editor works. But I can say, I recently discovered that times in time condition before and after parameters seem to need to be quoted, whereas times in time trigger at parameters do not. It’s probably safest to always quote times. If the editor isn’t doing that properly, then that sounds like a bug.
