I have a 6am alarm, which didn’t run this morning (thankfully I was awake lol), however when I ran it manually at 6:10, the actions worked. This is the automation:
alias: Alarm - 6am Weekday
description: ""
triggers:
- trigger: time_pattern
hours: "6"
minutes: "0"
seconds: "0"
conditions:
- condition: time
weekday:
- mon
- tue
- wed
actions:
- action: script.bedroom_play_music
metadata: {}
data: {}
- action: light.turn_on
metadata: {}
effect: Sunrise
profile: Sunrise
device_id: ba69d9b376a97007a9e3c1f4ce75534e
mode: single
This is the script.bedroom_play_music:
alias: Bedroom - play chill music
sequence:
- data:
device_name: Bedroom Echo Dot
uri: spotify:playlist:37i9dQZF1EIhgfi5yT3B9p
random_song: true
action: spotcast.start
And this is the error:
Logger: homeassistant.components.script.bedroom_play_music
Source: helpers/script.py:526
integration: Scripts (documentation, issues)
First occurred: 06:00:03 (1 occurrences)
Last logged: 06:00:03
Bedroom - play chill music: Error executing script. Unexpected error for call_service at pos 1: http status: 404, code:-1 - https://api.spotify.com/v1/me/player/play?device_id=3d107b00-8bcc-4929-a6fd-910ab947ba03_amzn_1: Not found., reason: None
File "/usr/local/lib/python3.13/site-packages/spotipy/client.py", line 271, in _internal_call
response.raise_for_status()
File "/usr/local/lib/python3.13/site-packages/requests/models.py", line 1024, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://api.spotify.com/v1/me/player/play?device_id=3d107b00-8bcc-4929-a6fd-910ab947ba03_amzn_1
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2795, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
return await self._hass.async_add_executor_job(target, service_call)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/config/custom_components/spotcast/__init__.py", line 378, in start_casting
raise exc
File "/config/custom_components/spotcast/__init__.py", line 349, in start_casting
spotcast_controller.play(
client,
...<5 lines>...
start_position,
File "/config/custom_components/spotcast/spotcast_controller.py", line 389, in play
client.start_playback(**kwargs)
File "/usr/local/lib/python3.13/site-packages/spotipy/client.py", line 1821, in start_playback
return self._put(
self._append_device_id("me/player/play", device_id), payload=data
File "/usr/local/lib/python3.13/site-packages/spotipy/client.py", line 338, in _put
return self._internal_call("PUT", url, payload, kwargs)
File "/usr/local/lib/python3.13/site-packages/spotipy/client.py", line 293, in _internal_call
raise SpotifyException(
...<5 lines>...
spotipy.exceptions.SpotifyException: http status: 404, code:-1 - https://api.spotify.com/v1/me/player/play?device_id=3d107b00-8bcc-4929-a6fd-910ab947ba03_amzn_1:
