I’ve been using HA (Hassio) for a while now and recently configured an automation based on geolocation (Owntracks) and Presence Detection (Router Huawey). When I enter the geolocation “HOME”, it turns a sonoff basic ON and then I turn it off manually. The automation works OK when I arrive home but what happens is that when I wake up, the lamp is turned on again. I can see on the events that the lamp turned on but I don’t see the automation event. I know that throughout the night, the presence detections shows several events due to Wifi losing connection but I don’t really leave the marked area.
Example of an automation event that runs as it’s supposed too:
20:45 - Candeeiro Hall turned off --> I manually turned off the sonoff
20:43 - Luzes turned on --> “Lights” group
20:43 - Candeeiro Hall turned on --> Sonoff turned on
20:43 - Pedro got home has been triggered --> Automation
20:43 - tracker changed to home --> Based on Owntracks
20:43 - Pedro ET is at home --> I get home
And then, the next morning, the following sequence of event happened:
11:29 - tracker changed to not_home
11:29 - Pedro ET is away
09:29 - Luzes turned off
09:29 - Candeeiro Hall turned off --> I woke up and turned it off
08:25 - Luzes turned on
08:25- Candeeiro Hall turned on -->It turned on all by itself…
08:07 - yr Symbol changed to 1
07:34 - Sun has risen
06:07 - yr Symbol changed to 3
03:07 - yr Symbol changed to 1
01:07 - yr Symbol changed to 3
I can’t really understand what’s happening…can someone point in the right direction?
