What matters to me from there are two pieces of information: state_topic: 'home/catfeeder/remaining and value_template: "{{ as_timestamp(states.sensor.cats_last_fed_mqtt.state) | timestamp_custom(' %d/%m %H:%M ') }}"
My automation should run if āremainingā is less than āxā value and 4h or x hours have passed since ālastfedā.
Iām not at all familiar with the Home Assistant environment, and tried something like this, but I know it doesnāt make sense:
alias: Alimentar Gatos
description: ''
- platform: state
entity_id: sensor.catfeeder_remaining
to: '10'
condition:
- condition: state
entity_id: sensor.cats_fed
state: '>4'
- service: script.57658975357
mode: single
I am not 100% sure if I fully understood your request.
So you automation should run when:
a) the āsensor.catfeeder_remainingā is lower than 10
OR
b) lastfed is longer than X hours ago
for b) I would recommend to create a template binary_sensor. (You have created a ānormalā sensor holding a formatted time value. This is fine if you would like to show it somewhere in your UI, but for automations I think the binary_sensor would be the better approach.
ah one secondā¦I think i now understood more better.
We are:
a) the āsensor.catfeeder_remainingā is lower than 10 and the last time automation was executed (fed was done) > 4 hours
OR
b) lastfed is longer than X hours (assumable > 4hours) hours ago.
In this case we should slightly modify:
description: ''
- id: 'remaining_low'
platform: numeric_state
below: 10
- id: 'always_after_x'
#x (at the moment 4hours) can be adjusted within the sensor to a value you like to have.
platform: state
to: 'on'
condition:
- condition: or
conditions:
- condition: and
conditions:
- condition: trigger
- condition: template # last executed 4 hours (= 14400 seconds) ago
value_template: "{{ as_timestamp(now()) - as_timestamp(state_attr('automation.alimentar_Gatos', 'last_triggered')) | float > 14400 }}"
mode: single
Thank you very much for your reply. You did all the work for me. I donāt quite understand why in the condition you use āandā and āorā and not just use the condition as ātemplateā . I use googe translate since my english is not good
The difference is that the first one converts datetime objects into timestamps and then subtracts them whereas the second one subtracts datetime objects directly.
