Automation - execute curl command
I tried for several hours create automation for below scenarios:
1.In case ‘device_tracker.me’ change to ‘home’
Execute CURL command (only one execute).
2.when ‘device_tracker.me’ is other then ‘home’
execute CURL command (only one execute).
before the automation i want to make sure the curl working preperly from HA.
curl --digest -u admin:pass -g '192.168.1.9/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=false''
Tried to execute with shell_command - not working, i verified simple TOUCH command working,i tried also escape all special characters .
rest_command - same
rest_command.yaml
set_on: 'curl --digest -u admin:pass -g '192.168.1.19/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=true'
set_off: 'curl --digest -u admin:pass -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=false'
I guess some1 did something similar - would be thankful if u can share .
It’s very likely you’ll need to specify the full path to curl:
/usr/bin/curl --digest
Thanks FredTheFrong ,
if my command_line.yaml
looks like:
switch:
  - platform: command_line
    switches:
      lounge_ac_test:
        command_on: '/usr/bin/curl --digest -u user/pass -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=true''
        command_off: '/usr/bin/curl --digest -u  user/pass  -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=false''
How do i execute it from automation ?
i started with :
 - alias: 'Set mask OFF salon IPC'
   initial_state: 'on'
     platform: state
     entity_id: 'device_tracker.avi'
     to: 'not_home'
     **- service: <--- Not sure for this part**
     - service: notify.telegram
         message: 'Masking camera salon'
again, i need this to be executed once the status changed (‘home’ -->‘not_home’).
what is the proper way to make this automation?
dont really like the hard coded curl commands ,
cause it actually same command with either true/false.
Use the switch name as an object, and specify the turn_on action:
action: switch.lounge_ac_test.turn_on
Thanks FredTheFrog ,
I set the command_line.yaml as following
switch:
    switches:
      salon_masking:
        command_on: "/usr/bin/curl --digest -u user/pass -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=true'"
        command_off: "/usr/bin/curl --digest -u user/pass -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=false'"
This part pass validation ,
The problem is with automation.yaml:
   initial_state: 'on'
     platform: state
     entity_id: 'device_tracker.me'
     to: 'not_home'
     switch.salon_masking.turn_on
I tried also:
 action: switch.salon_masking.turn_on
getting error:
Invalid config for [automation]: expected a dictionary @ data['action'][0]. Got None. (See /config/configuration.yaml, line 174). Please check the docs at https://home-assistant.io/components/automation/
I apologize, I was running too many things together (thinking in another computer language at the time!)
  - entity_id: switch.salon_masking
    service: homeassistant.turn_on
Thanks @FredTheFrog
I set debug on :
logger:
  default: debug
Execute the command from developer tools
the command seems correct but nothing happened:
2019-09-03 09:17:00 INFO (SyncWorker_4) [homeassistant.components.command_line.switch] Running command: curl --digest -u admin:passs -g '192.168.1.108/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[].EncodeBlend=false'
2019-09-03 09:17:00 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.140469103335440] Sending {'id': 22, 'type': 'result', 'success': True, 'result': None}
i also tried executing the curl command as:
/usr/bin/curl
curl
also as /sbin/curl
as when running in terminal
[~] # which curl
/sbin/curl
When i execute the command in terminal it working properly ,
I’m running HA 0.97.2 on a docker( qnap NAS ),
I read somewhere(can’t find it now) that in some cases it may work if execute cur; commands as python command but not sure how implement/try that .
