Logger: homeassistant.config
Source: config.py:443
First occurred: 4:54:54 PM (1 occurrences)
Last logged: 4:54:54 PM
Invalid config for [automation]: invalid time_pattern value for dictionary value @ data['hours']. Got None. (See /config/configuration.yaml, line 5).
here is my automation.yaml
- id: '1624449501449'
alias: Watering Automation
description: water 45 seconds every 2 hours
- platform: time_pattern
hours: "{{ states('input_number.Hour') | int }}"
condition: []
- service: script.watering_script
mode: single
Can you please help me out?
I don’t know what format should I choose for my input_number.Hour…
That will trigger every hour for minimal system load, then only continue if the hour part of the time is divisible by the value of your input_number (which I think must/can be lower case).
Yes you do not need to worry about lagging or delay, it will be almost instantaneous, whenever input value is changed, automation will kick in (at worst a second delay, might depend on home assistant performance)
