Automation fail when using condition sun
I’m trying to create an automation when the door opens the light goes on. But i want it only to happen after sunset and before sunrise. The moment i put the part condition in my automation it stops working and i have an error next to condition. Any ideas?
See the examples here: https://www.home-assistant.io/docs/scripts/conditions/#sun-condition
Also, please don’t post screenshots of text. It is impossible for us to edit and correct.
Just wanted to show the error beside the code :wink:
In any case this is the full code no more errors in the file editor but now i get a strange error in the log.
- id: '1608156855532'
  alias: deur licht aan gang
  description: ''
  - type: opened
    platform: device
    device_id: 2bbe457e13d27e811b16afa618d988aa
    entity_id: binary_sensor.deur_naar_gang
    domain: binary_sensor
    condition: or
    conditions:
    - condition: sun
      after: sunset
    - condition: sun
      before: sunrise
  - service: switch.turn_on
    data: {}
    entity_id: switch.sonoff_voordeur
  mode: single
  • Invalid config for [automation]: required key not provided @ data[‘trigger’][1][‘platform’]. Got None. (See /config/configuration.yaml, line 10).
  • Invalid config for [automation]: [condition] is an invalid option for [automation]. Check: automation->condition. (See /config/configuration.yaml, line 10).
configuration.yaml line 10 is this:
group: !include groups.yaml
You’re trying to include your OR condition in your trigger, that’s not where it goes.
Needs to be in the condition block…
  description: ''
  - type: opened
    platform: device
  condition:
    condition: or
    conditions:
    - condition: sun
      after: sunset
    - condition: sun
      before: sunrise
    data: {}
  mode: single
Yep that was it :man_facepalming:
I find it very confusing to put the word condition 4 times in there… I tried several ways but they failed every time.
Thanx for the advice!
First one is the condition block of the automation, second one says that you want to use an OR condition, third and fourth are the conditions you’re ORing.
