I’m currently trying to setup the automation with the help of the trigger numeric_state and Slack as an action, but I’m a bit struggeling. The automation looks like this:
automation:
- alias: Temperature Dario Bedroom
platform: numeric_state
entity_id: sensor.temperature_dariobedroom
above: 20
service: notify.smarthome
message: "Temperature in Dario's room is above 20°C"
But I get the following error:
2017-07-24 00:06:34 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [automation] is an invalid option for [automation]. Check: automation->automation. (See /home/dario/.homeassistant/configuration.yaml, line 147). Please check the docs at https://home-assistant.io/components/automation/
My guess, based on the error message, is that you already have automation: defined in your configuration.yaml, and that the automation you have quoted is in a separate file (maybe automations.yaml ?)
If so, remove the automation: line from your automation and move everything below it back two spaces:
above: 20
