I am trying to use the result of a rest call to automate a hue scene. while I can view the sensor attributes in a test card, and I can manually run services to change the hue scence, I can’t put it all together into the correct automation script.
I have the below sensor:
The sensor is a rest call to https://api.coingecko.com/api/v3/simple/price?ids=filecoin&vs_currencies=usd&include_24hr_change=true
The result doesn’t seem to be true json (it has single quotes rather than double quotes) so i changed value_template. The fact that the cards work and let me retrieve the usd and the usd_24h_change attributes. The sensor yaml is:
- name: "Crypto - Filecoin"
json_attributes_path: "$.filecoin"
value_template: '{% set result = value_json|to_json %}
{{ result.filecoin.usd_24h_change }}'
json_attributes:
- filecoin
- usd
- usd_24h_change
Finally, my automation file is:
- id: '1635056726769'
alias: Green 24hr change positive
description: Change Light Colour
- platform: time
hours: 0
minutes: '/1'
seconds: 0
condition:
condition: template
value_template: '{{ (state_attr("sensor.crypto_filecoin.usd_24h_change")|int) > 0 }}'
action: call-service
service: hue.hue_activate_scene
service_data:
group_name: Living room A1
scene_name: Stonks only go up
Which can be saved, but i get the below error in the log files:
Invalid config for [automation]: expected dictionary @ data['action'][0].
Got None extra keys not allowed @ data['service'].
Got None extra keys not allowed @ data['service_data'].
Got None invalid template (TemplateSyntaxError: unexpected ')') for dictionary value @ data['condition'][0]['value_template'].
Got None. (See /config/configuration.yaml, line 9).
I’ve tried various options and i still get the unexpected ‘)’. HA is pretty new to me but I’ve been able to find most problems i have had recently online. The problem now might be related to a few different issues so it is harder to google. Any help would be appreciated.
